Is there any "unpublished" method to cast and get a python object in the MAX C++ SDK?
denisT.MaxDoctor
Advisor Advisor
denisT.MaxDoctor
I want Qt objects to be passed as PyWrapperBase to the SDK...is there something that can be done?
def_visible_primitive(isPyWrapper, "isPyWrapper");
Value* isPyWrapper_cf(Value** arg_list, int count)
	check_arg_count_with_keys(isPyWrapper, 1, count);
	auto val = arg_list[0];
	if is_pywrapperbase(val)
		// ... some cast is expected here ...  ;
		return &true_value;
	return &false_value;
denisT.MaxDoctor
for QWidgets, you can pass winId() and then find the widget, but I'm interested in a more universal solution
eric.brosseau
@denisT.MaxDoctor
The answer to the question in the title is no, there is no hidden method to suit your request as of today. We currently only interface with Python using the MAXScript/pymxs interface. From C++, you would have to extend the MAXScript exposure with the methods you need to interface with. For Qt objects, it is preferable to use the Qt/PySide2 Python module and not use the pymxs interface.
Is there anything blocking you from achieving your goal?
Eric Brosseau
Eric Brosseau
Senior Software Developer, 3ds Max, Autodesk
denisT.MaxDoctor
@eric.brosseau wrote:
@denisT.MaxDoctor
As you might guess, it's for developing MaxScript extensions that I would like to be able to pass Py-Wrapped MXS values to the MAX SDK.
I think that this mechanism is simple and transparent if you know how it works, and I don't understand why this should be made a "secret".
Here is a simple task...
I have:
qwds = python.import "PySide2.QtWidgets"
wd = qwds.QWidget()
now I want to pass "wd" to some visible SDK primitive function to get a wrapped QWidget in C++. How? (not using the winId)
I just want to confirm what Eric said. A python object can only become visible to max through pymxs. Pymxs wraps a python object as a maxscript object. From the moment it is wrapped, its properties and methods become usable as maxscript properties and methods. This is the only thing that exists right now.
denisT.MaxDoctor
But I still want an answer to a simple question: How can I pass a pointer to a QObject wrapped as a Python object to the MAX SDK?
If 'pymax' can do it, why can't I do the same? ... just answer what exactly does PyWrapperBase point to or how to get a pointer to a python object?
denisT.MaxDoctor
using shiboken2 and its getCppPointer method, we can get the address of the c++ instance pointer wrapped by the given object... after that, everything is clear.
