Announcements
intersectRay confussion help please
remainz
remainz
Help
I dont understand why I dont get a point3 out of intersectRay?
MyRay = ray $Camera001.pos $Box001.pos
intersection = intersectRay $Plane001 MyRay
$Box001.pos = intersection
 return
OK
(ray [-225.949,-153.093,273.755] [-0.0378324,0.989376,0.140368])
(ray [-250.611,491.859,365.258] [-0.612372,-0.612373,0.5])
-- Error occurred in anonymous codeblock; filename: ; position: 187; line: 8
-- Unable to convert: (ray [-250.611,491.859,365.258] [-0.612372,-0.612373,0.5]) to type: Point3
 thanks for you time
remainz
It needs $Box001.pos = intersection.pos
denisT.MaxDoctor
The error message says 8 lines, but you only show three lines of code.., where is the rest? 😉
remainz
Thanks guys. I was getting confused about the code because the intersectRay was not working properly.
When I move the $Box001 to the intersect point it is nowhere near where it is supposed to be.
I was using a plane and all I was getting was errors so I got confused.
When I use a sphere the code works but shows that its so off target that a plane could not work.
See pics of issue where before the code the $Box is in shot
but after using the intersectRay position it moves way out of shot.
intersection = intersectRay $GeoSphere001 MyRay
Is this normal behavior?
I've tried it on previous version of Max and it was the same!
denisT.MaxDoctor
delete objects
gc()
bx = box width:30 length:30 height:30 pos:[0,-15,-30]
sp = converttomesh (geosphere name:#mesh segments:8 radius:20 wirecolor:orange) + bx
delete bx
cm = targetCamera pos:[0,-200,100] target:(targetObject())
i_point = point name:#intersection cross:on axistripod:on wirecolor:green
fn check_intersect =
	intersection = intersectray sp (ray cm.pos -cm.dir)
	if intersection != undefined do
		i_point.pos = intersection.pos -- intersection point
		i_point.dir = intersection.dir -- mesh's normal in intersection point
	intersection
deleteAllChangeHandlers id:#intersect_test
when transform #(sp,cm) changes id:#intersect_test obj do (check_intersect())
check_intersect()
here's a snippet of code that should help you understand how things work.
remainz
Awesome thanks a lot!
I learned a lot.
Idiots version
intersection = intersectray $Plane001 (ray $Camera001.pos -$Camera001.dir)
Note "-$" not "- $"
