interacting with python, how?!?
jens.diemer
jens.diemer
We have the simple python interface: http://help.autodesk.com/cloudhelp/2015/ENU/MAXScript-Help/files/GUID-860B6BEB-AE3E-4F99-96E9-CCD70D...
But how can i send and receive information between maxscript and python?!?
The only information from python to maxscript are the return codes:
#success | #pathError | #initError | #scriptFileError | #executeError
That's all?!?
Must i use a temp file for communications?!?
Jens
https://github.com/jedie/3dsmax_bugs | https://github.com/jedie/3dsmax_patches
kevinvandecar
Yes, as you see in the documentation there is limited interop between MAXScript and Python. From MAXscript, getting data from Python is not diorectly possible. But you can also execute MAXScript from python and there you have more ability to get data from the MAXScript environment. See here:
http://help.autodesk.com/view/3DSMAX/2015/ENU/?guid=__files_GUID_050A2EBF_A176_49B8_8ED4_14FC2301531...
hope it helps,
kevin
Kevin Vandecar
Developer Technical Services
Autodesk Developer Network
