Announcements
Instances from Compound Scatter object
Hello! How in C++ SDK to read actual matrix transformations and referenced object mesh for scatter compound object?
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/3DSMa...
I have lost digging in SDK, can't find it.
Currently obj->GetRenderMesh method give collapsed bug mesh that contains all resolved and transformed instances. It can be a lot of geometry.
Best regards,
Aaron
denisT.MaxDoctor
you have to look at the reference targets of the object ...
as I can see they are under the reference target 0 - (Scatter: source) and 1 - (Scatter: distribution) (2nd and 3rd reference targets are transforms)
after that you have to query the reference targets of the source and distribution Scatters to get their objects ... and so on
How to do that in c++ sdk?
denisT.MaxDoctor
Are you kidding?
ReferenceTarget:: GetReference(int i);
denisT.MaxDoctor
This amazes me - I want to do it with the SDK!
Let's first figure out how it is all assembled and how it works!
go to the mxs listener and run something like:
fn dumpReferenceTargets obj token:"" recurse:on = if isvalidobj obj do
	num = refs.getnumrefs obj
	format "%% (%)\n" token obj num
	for k=1 to num do
		ref = refs.getreference obj k
		format "%\t% > %\n" token k (if ref != undefined then ref else "")
		if recurse do dumpReferenceTargets ref token:(token + "\t") recurse:on
dumpReferenceTargets < compound scatter >
after you understand the base you can implement it with c++
I will look into this direction, thanks for advice! 🙂
As for kidding, I just was writting from cell phone without help manual under my hand
