import sketchup files using Python
Message 1 of 8
How to import sketchup furniture models using python code in 3ds Max?
Replies (7)
Message 2 of 8
drew_avis
Something like this should work:
import pymxs
from pymxs import runtime as rt
myfile = 'C:\\Users\\avisd\\Desktop\\Sample+House.skp'
rt.importFile(myfile, using=rt.sketchUp)
Hope that helps,
Drew
Drew Avis
Content Experience Designer
Message 3 of 8
Thanks but the method is always returning false and not importing anything. I tried it with different files and different paths.
Any idea why?
Message 4 of 8
drew_avis
What version are the sketchup files?  Max can import Sketchup 2014 and lower.
Drew
Drew Avis
Message 5 of 8
they are 2014. I can successfully import them manually, scripting is when the issue occurs.
Message 6 of 8
drew_avis
What version of Max are you using?  Can you post your code snippet?
Drew
Drew Avis
Message 7 of 8
I fixed the problem. I needed to add .skp at the end of the file name. Thank you!
Message 8 of 8
drew_avis
Aha!  Glad you figured it out.
Drew
Drew Avis
