Import Revit file by using max script
When I import a Revit file, can the "select revit view" option in the Import Settings dialog be controlled by using max script? If so, which API should I use?
I found the Revit_importer interface in the tutorial "MAXScript Help", but it can't control the "select revit view" option.This is the link to the interface: http://help.autodesk.com/view/3DSMAX/2018/ENU/?guid=__files_GUID_C6560DDD_3117_4F8B_9280_F990D240F29...
drew_avis
Hi, I believe you can use the RevitImporterSetOption <String>optionName <Value>newValue API, using "view" as the optionName.
Hope that helps,
Drew
Drew Avis
Content Experience Designer
Hi Drew, I have solved this problem, thank you very much for your help.
