I need a script code for align axis to world
Waseem_Dabbas
Message 1 of 11
Waseem_Dabbas
I want to make code that aligns the Z axis of a certain element's center to the Z axis of a scene?
in short, I want the code of this button 👇🏻
Replies (10)
Message 2 of 11
denisT.MaxDoctor
see MXS Help:
Same as Hierarchy/Pivot/Affect Object Only - Align to World.
AlignPivot <node>-- mapped method
Message 3 of 11
Waseem_Dabbas
@denisT.MaxDoctor
Thank you for answering
After Writing the code, nothing happened, did I miss something?
The Z axis of the selected object should follow the Z axis of the scene.
Message 4 of 11
denisT.MaxDoctor
alignPivot $
hmm... you need to learn MaxScript syntax if you want to use it.
Message 5 of 11
istan
a typical "CG" problem 😉
Message 6 of 11
Waseem_Dabbas
For those who have the same question, here is the solution:
   for i in selection do
        WorldAlignPivot i
Message 7 of 11
denisT.MaxDoctor
Funny how it goes... in the MXS Help, the distance from AlignPivot to WorldAlignPivot is just three lines, but in real life, it takes a year and a half to get through them.
It will probably take another year and a half to learn what a “mapped function” is...
Message 8 of 11
istan
But the help is not quite right on this point either. It should rather be <node | nodecollection>, if collections can also be passed.
Message 9 of 11
denisT.MaxDoctor
I didn't say you have to follow Help exactly... it was enough to believe what I said and check how it works. 😎
Message 10 of 11
istan
wrong receiver..
I always trust you! 😁
Message 11 of 11
istan
