I have a problem with the interface, please help.
C1.JPGHello.
I have had a problem (REF  #1) WRT the widow that shows my edit layers. As you can see it is still there however I can't see what's in the window. I can't expand it or even click on it. I showed it to my instructor but even he hasn't seen it before. He told me to e-mail you and see if you can help.
(REF # 2)  WRT my robot I have made during the holidays. the right leg is a shift and drag copy of the left leg then mirrored. The right quad turned black for some reason.
Please help.
Thank you for your time on this matter.
                                                 Chris deBeaupre
istan
I dont know the answer, but others would probably need a version information at least..
miauuuu
What is the user scale factor? You can check it by executing this command in the maxscript editor:
CustomControlsOptions.UIUserScaleFactor
https://miauu-maxscript.com/
