how to use the same object in each button ?
Hello.
In the code below I create two buttons. I wanted to use the same object that I could update and use to setup data in each button. But I hit the wall. If I try to use object already created in my struct, inside button Event, I get:
Runtime error: Struct member access requires instance: _dataContainer <<
with this code:
struct MyContainer
public
lockView = true
struct TestUI
private
text = "hello",
_dataContainer = MyContainer(),
public
fn Create =
rollout MainWindow "Test"
button GI_btn @" GI " width:100 _height:30 pos:
button Farm_btn @" FARM " width:100 height:30 pos:
/* EVENTS ---------------------------------------- */
on GI_btn pressed do
_dataContainer.lockView = true
on Farm_btn pressed do
messagebox (_dataContainer.lockView as string)
createDialog MainWindow 200 200
_ui = TestUI()
_ui.Create()
Now if I modify the code:
struct MyContainer
public
lockView = true
struct TestUI
private
text = "hello",
public
fn Create _dataContainer =
_my = MyContainer()
_ui = TestUI()
_ui.Create _my
and try to pass data thru function and then use them in button events, i get:
Compile error: No outer local variable references permitted here: _dataContainer
So, how to correctly pass the same object into each button so I could work with the same data in each ?
Steve_Curley
The order in which you define things in Rollout code is important. See:-
Visibility of Locals, Functions, Structures and User-Interface Items in Rollout Code
in the Maxscript Help.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
I can modify code like this:
struct MyContainer
public
lockView = true
struct TestUI
private
text = "hello",
public
fn Create =
local _dataContainer = MyContainer()
_ui = TestUI()
_ui.Create()
and it will work perfectly.
Now lets create different setup:
struct MyContainer
public
lockView = true
struct TestUI
private
text = "hello",
_data = MyContainer(),
_buttonsRollout,
_buttonsRolloutName = "Buttons",
_optionsRollout,
_optionsRolloutName = "Options",
public
fn Create =
rollout _buttonsRollout _buttonsRolloutName
/* UI elements ---------------------------------------- */
button GI_btn @" GI " width:60 height:30 pos:
button Farm_btn @" FARM " width:60 height:30 pos:
messagebox (_data.lockView as string)
rollout _optionsRollout _optionsRolloutName
MainWindow = newRolloutFloater "Bake Utils" 200 200
addRollout _buttonsRollout MainWindow
addRollout _optionsRollout MainWindow
_ui = TestUI()
_ui.Create()
Now I would like to acces the same data not only in buttons but also in both rollouts.
In this example adding "local _dataContainer = MyContainer()" to first rollout will not help. If I define MyContainer as global it will work , but I don't want to do this. After reading part of documentation you mentioned I still don't get this. If rollout can use private variable from struct as its name, why it can't use variable in button event ?
Do you have any code example ?
Solution for the problem link
