How To Supress Bitmap Proxy Settings Popup ?
I have made a script that loads bunch of files.
Each call to "loadmaxfile filepath quiet:true",
causes max to popup a proxy settings window, prompting user to
generate proxy files. Script must not generate any files and
run without user interaction.How to supress this popup ?
Thank you.
btw... I will try with DialogMonitorOPS tommorow...
Steve_Curley
DialogMonitorOps will not suppress the dialog, it will allow you to automate any response TO the dialog. Plus it's a PITA to use...
If you get that warning when you open one of those scenes normally, maybe it would be better to generate those proxies once so the dialog doesn't appear. Not overly familiar with proxies so that is just a guess.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
I got it working.
callback function:
fn ProxySystemPopupRejectCallback = (
_hwnd = DialogMonitorOPS.GetWindowHandle()
_windowText = (UIAccessor.GetWindowText _hwnd)
if _windowText == undefined do return true
if (matchpattern _windowText pattern:"Proxy System") do (
UIAccessor.SendMessageID _hwnd #IDNO
true
enable:
DialogMonitorOPS.RegisterNotification ProxySystemPopupRejectCallback id:#bprpkillcb
DialogMonitorOPS.Enabled = true
DialogMonitorOPS.ShowNotification()
disable:
DialogMonitorOPS.Enabled = false
DialogMonitorOPS.unRegisterNotification id:#bprpkillcb
Thank you for your answer Steve_Curley. Script will work on a remote
machine where is no user to click the button 🙂
Cheers,
cgBartosz
