How to pass a points arry to a Dotnet function
flyingc007
Message 1 of 9
flyingc007
I have an array of points,such as #([1,3,4],[53,12,1])
If I want to pass it as an argument to a DotNet funtion .
How would I do?
Thanks in advance.
Replies (8)
Message 2 of 9
flyingc007
(where do I edit the post?I can't find )
This question  is about MAXScript.
I need to pass an argument of  points array to a DotNet function.
Message 3 of 9
istan
Visual Studio / Solution / References / Add Reference: "3dsmax_path\Autodesk.Max.DLL"
Then use the object browser. There you'll find everything Max is exposing to dotNet.
There's another interesting one: MaxCustomControls.DLL
Message 4 of 9
denisT.MaxDoctor
it depends on the type of dotnet function you are using ... show your function definition to see the type of input data
Message 5 of 9
flyingc007
For example.
I have a point3 struct,and a sum function like this
public struct point3
        public float x, y, z;
        public point3(float x1, float y1, float z1)
            x = x1;
            y = y1;
            z = z1;
public static point3 sum(int num,point3[] pts)
            for (int i = 1; i < num; i++)
                pts[1].x += pts[i].x;
                pts[1].y += pts[i].y;
                pts[1].z += pts[i].z;
            return pts[1];
I want to call the function in MaxScript,so the problem is how to pass a points array to the sum() function.
Message 6 of 9
flyingc007
sorry ,I forgot to mention one thing.
I need to call the function in 3dsmax 2012 or below the version.
But "Autodesk.3dsmax.dll" is not availibale in these version.
Message 7 of 9
istan
arr=#( dotnetobject("mydotnetclass.point3") 1 2 3, dotnetobject("mydotnetclass.point3") 4 5 6)
local ret = dotnetclass("mydotnetclass").sum arr.count arr
I'd do it somehow like this under Max2020..
Message 8 of 9
flyingc007
Yes,it can work,but it seems a bit complex
 it will be much better if the array can be turn to pointer to a memory.
Message 9 of 9
denisT.MaxDoctor
@flyingc007 wrote:
it seems a bit complex...
pass it as a pointer to float's array... and cast in c# .. three floats per point
