How to pass a MaxScript bitmap to C++ using function-publishing
Message 1 of 8
Greetings,
I have a question regarding how to pass a MaxScript bitmap to C++ using function-publishing?
I use the following definition for my function-published interface
void SetImage(PBBitmap &bmap);
PBBitmap& GetImage();
PROP_FNS(IFP_OpenVINO::em_getBmap, GetImage, IFP_OpenVINO::em_setBmap, SetImage, TYPE_BITMAP_BV)
And on the MaxScript side I use
myBitmap = openBitmap <some-path to an image>
fp.Image = myBitmap
showproperties myBitmap
My expectation is that on the C++ side my GetImage has received by-value a MXS Bitmap object that I can work with.  This is not working as I am getting trash.  Might anyone be so kind as to pointing me to working samples or how-tos that demonstrate proper usage of function-publishing and bitmaps?
Replies (7)
Message 2 of 8
istan
not sure, but have you also tried "by reference" instead of "by value"?
Message 3 of 8
Greetings Istan -
I have approached the problem both ways - taking the Bitmap objects from Maxscript to C++ both by-value and by-reference.  In both cases I get clean builds - so no insight from the compiler - and Maxscript seems perfectly happy in passing the Bitmap object to the C++ layer.  However, when I set a breakpoint in my C++ getter I am still getting trash.
I have reviewed the HowTo.sln and specifically the FunctionPublishing project for guidance and that is where I am coming from.  What I really would like is a bit of code-sample - either from the samples or from elsewhere - that demonstrate either thru FnPub or through traditional paramblock2 how to pass a Bitmap from MXS to C++ layer.
Let me know if you have additional questions ... RudyC
Message 4 of 8
klvnk
MXS will pass it as a MAXBitMap value not a Bitmap so you could try it as a TYPE_VALUE not TYPE_BITMAP
then do something like...
void SetImage(Value* val)
if(val->tag == class_tag(MAXBitMap)) //maxscript.h/value.h { MAXBitMap* maxbitmap = (MAXBitMap*)val; Bitmap* bm = maxbitmap->bm; if(bm)......
Message 5 of 8
klvnk
you could also try is like this
void SetImage(Bitmap *bmap);
Bitmap* GetImage();
PROP_FNS(IFP_OpenVINO::em_getBmap, GetImage, IFP_OpenVINO::em_setBmap, SetImage, TYPE_BITMAP)
Message 6 of 8
klvnk
the value version works as expected
the other method partially...
though it should be
void SetImage(PBBitmap *bmap);
PBBitmap * GetImage();
unfortunately only the bitmapinfo ptr of the PBBitmap is valid the Bitmap is a null pointer and you can only pass "saved"/loaded bitmaps which is odd though it could be bug in the version i use
Message 7 of 8
Thanks klvnk -
I tried your approach and can see the situation in Max 2019 ... the PBBitmap has data and the ptr to Bitmap is null.  It indeed might be a bug.
RudyC
Message 8 of 8
klvnk
the value version works ok though, you could get it to throw typical max script errors so from the mxs side theres no difference.
