How to know if a material's name is Exist? SDK(C++)
xiaobin
Message 1 of 10
xiaobin
When I create a new material, I need known Is the name unique. If I do not judge in advance, the system will create multiple materials with the same name.
Replies (9)
Message 2 of 10
istan
Why you don't use ip->AssignNewName(Mtl *m)  ?
Message 3 of 10
xiaobin
This function will rename the new material whether or not it has the same name.
Message 4 of 10
istan
there's also a "NameMaker" class..
Message 5 of 10
denisT.MaxDoctor
the only one safe way to do it is collect all material names (scene or any other material collection) and check new name against this list.
built-in 'new name' or 'unique name' logic was always broken in the MAX system (IMHO)
Message 6 of 10
istan
well, I use it often and nobody complained so far 😉
Message 7 of 10
denisT.MaxDoctor
here are examples of 'broken' logic:
# the system doesn't check for uniqueness names with numeric suffix
# the system always offers a new name for whether it is used in the scene or not
# the NameMaker works with only 'root' names, that makes it useless when you want to check a names with numeric suffix
Message 8 of 10
denisT.MaxDoctor
b0 = box material:(Standard name:#std)
b1 = box material:(Standard name:#std_01)
b0.mat.name
b1.mat.name
okMtlForScene b0.mat
okMtlForScene returns TRUE for both materials but as you can see they both exist in the scene
Message 9 of 10
denisT.MaxDoctor
assignNewName b0.mat
it modifies the name but the original name was already unique for the scene...
is it not a 'broken' logic?
Message 10 of 10
denisT.MaxDoctor
check another example:
resetMaxFile #noPrompt
for k=1 to 9 do
	b = box material:(Standard name:("Material #" + (k+20) as string))
	format "% >> "b.mat.name
assignNewName objects[1].mat
objects[1].mat == objects[5].mat
objects[1].mat.name == objects[5].mat.name
