How to get the material instance id?
xiesansi
xiesansi
I have 2 materials with the same material name.
I'm trying to differentiate between them. I tried GetHandleByAnim, but as the document said, the handle did not "saved with the scene, and no guarantees are provided about handle values from one load to another."
How to get a persistent id of a material?
denisT.MaxDoctor
In general, when working with materials, you should avoid naming different materials by the same name. But it may be the case that we don't know and you must do it. Well...there are three most common ways to identify such scene objects, other than using their exact name:
   #0 use base name and unique id
   #1 use app data channel
   #2 use custom attribute
xiesansi
Thank you!
I prefer the first one since It would be better if I do not change the users' data...
Could you explain more about the unique id if animHandle does not work... Which method should I use?...
xiesansi
any one could help me with the id issue? Which method should I use to get a unique id?
denisT.MaxDoctor
rename materials by giving them a unique ID. use for example
genClassID
 to generate unique and random ids.
