How to get return values from the MaxScript command, "python.Execute"
I'm updating a pipeline from using 3dsMax2014 to using 3dsMax2019.
The previous pipeline used DuberPython. This is now replaced using the
"python.Execute" maxScript command.  I have not found any documentation on RETURN VALUES from that command.
Current workaround - writing results from python to the filesystem, then
reading them into the maxScript calling-function.
I would really love to not have to read/write to the filesystem.
Thanks in advance for all input!
Swordslayer
When you want that, it might be better to instead say myModule = python.import "myModulePath" and then call myModule methods directly from MAXScript.
Hey Swordslayer,
I will definitely do that. Thanks!
(I'm new to Max/MaxScript and the codebase I'm working with was for
max2014... I just wanted to replace duberPython and found that
python.Execute ALMOST fit the patterns of duberPython useage)
Thanks again.
