How to get camera Intrinsics?
thereisnocool
Observer Observer
thereisnocool
Observer
Observer
I want to convert 3d coordinates to 2d screen coordinates, which is inseparable from the internal and external parameters of the camera. At present, I calculated the external parameters of the camera by camera.transform, and calculated the internal parameters of the camera by the Angle of view, camera focal length (mm) and image resolution, but I finally got the wrong reprojection result. At present, I have confirmed that the external parameters are OK. Maybe there is a problem with the internal parameters. Perhaps the projection center of the virtual camera in 3Ds Max is not in the image center? Or was there a mistake in the way I calculated the focal length? I really don't understand
istan
search for "getCameraMatrix" on this board
klvnk
there's 3 alternatives depending on how you want the coords.....
in mxs it would be
fn World2Screen pt =
	gw.setTransform(Matrix3 1);
	gw.TransPoint pt /*gw.wTransPoint pt*/ /*gw.hTransPoint pt*/;
it's basically exactly the same functions in the sdk, also if you need to collect a lot of points screen positions a single call to a single call to setTransform beforehand will suffice.
