How to create dynamic trajectories for mesh vertices?
Hi all,
I have two editable meshes representing the same object at two different times. They are exactly the same (same number of points etc.), just in different configurations. I am studying the transition from time 1 to time 2. I applied the Morpher modifier to represent the motion between the two states. What I am interested in is to display the vectors that represent the displacement of each single vertex of the mesh between the initial and the final state. Basically I am looking for a way to connect corresponding vertices with a segment.
For now I have a script that creates static lines connecting corresponding vertices of the two meshes. I am wondering if it is possible to adapt this script in order to make it more dynamic. I mean like automatically adapting the lines when I move one of the two meshes to always keep them connected? I am thinking about displaying somehow the changes in the lines' lengths during an animation (while using the morpher modifier would be perfect, but probably not doable?). Also, is it possible to create arrows instead of lines? I'd be interested in displaying the vectors representing the motion of vertices (pointing to state2 from state1). Thank you a lot!!
Here is the script I am using:
-- Creates lines between corresponding vertices of two selected editable meshes.
-- No error checking is done.
-- v1 12/30/2020 LRM
fn Line2Points pointA pointB =
ss = SplineShape pos:pointA
addNewSpline ss
addKnot ss 1 #corner #line PointA
addKnot ss 1 #corner #line PointB
updateShape ss
ss
fn morph_vectors vstart vend =
-- Creates a line between corresponding vertices of two selected objects
-- that have the same number of vertices.
for i = vstart to vend do
pA = meshop.getVert objA i
pB = meshop.getVert objB i
newLine = Line2Points pA pB
objA = selection[1]
objB = selection[2]
nV = meshop.getNumVerts objA
nvt = nv as string
rollout vectorRollout3 "Morph Vectors" width:200 height:160
button 'btnGo' "Go" pos:[32,104] width:96 height:36 align:#left
edittext 'edt1' "" pos:[64,32] width:78 height:24 align:#left
label 'lbl1' "Start vertex" pos:[0,32] width:65 height:15 align:#left
edittext 'edt2' "" pos:[64,64] width:78 height:24 align:#left
label 'lbl2' "End Vertex" pos:[0,64] width:56 height:16 align:#left
label 'lbl3' "Total number of vertices:" pos:[0,8] width:120 height:17 align:#left
label 'labelnverts' nvt pos:[128,8] width:48 height:19 align:#left
on btnGo pressed do
vstart = edt1.text as integer
vend = edt2.text as integer
messagebox "Done"
createdialog vectorRollout3
denisT.MaxDoctor
you can look at Scripted Manipulators.
this is the most efficient solution for this kind of tasks
denisT.MaxDoctor
here is an example how to work with Scripted Manipulator...
plugin simpleManipulator MorphTracksManipulator
classID:#(0x2feb0000, 0x00ddc02)
silentErrors:off
category:"Manipulators"
	local node, giz
	local source_mesh
	local target_mesh
	fn getThisNode = (refs.dependentnodes this)[1]
    parameters params rollout:params
		source_node type:#node subanim:on ui:ui_source
		target_node type:#node subanim:on ui:ui_target
	fn isGeometryNode node = isvalidnode node and iskindof node GeometryClass
	rollout params "Parameters"
		group "Geometry: "
			pickbutton ui_source "< Source >" width:144 autoDisplay:on filter:isgeometrynode align:#left offset:[-4,0] \
				tooltip:"Pick Source Node"
			pickbutton ui_target "< Tareget >" width:144 autoDisplay:on filter:isgeometrynode align:#left offset:[-4,0] \
				tooltip:"Pick Target Node"
	tool create
		on mousePoint click do
			nodeTM.translation = [0,0,0] --gridPoint
			#stop
	on canmanipulate target do return true
	fn makeMorphTracks =
		node = getThisNode()
		node_tm = inverse node.transform
		line_color = node.wirecolor as point4
		if isGeometryNode target_node and isGeometryNode source_node do
			this.clearGizmos()
			source_mesh = source_node.mesh
			target_mesh = target_node.mesh
			source_tm = source_node.transform
			target_tm = target_node.transform
			num = amin source_mesh.numverts target_mesh.numverts
			for i=1 to num do
				giz = manip.makeGizmoShape()
				giz.startNewLine()
				p0 = getvert target_mesh i * target_tm
				giz.addPoint p0
				p1 = getvert source_mesh i * source_tm
				giz.addPoint p1
				giz.transform node_tm
				this.addGizmoShape giz (gizmoActiveViewportOnly) line_color line_color
	on updateGizmos do
		makeMorphTracks()
-------------- Test scene setup: ----------
gc()
delete objects
src=geosphere name:#source wirecolor:orange pos:[-50,0,0]
trg = torus name:#target wirecolor:green pos:[50,0,0]
rotate trg (angleaxis 90 y_axis)
manuip_node = MorphTracksManipulator name:"MorphTracker" isselected:on wirecolor:yellow
manuip_node.source_node = src
manuip_node.target_node = trg
but there are many more things you need to learn. The main issue with all script manipulators is how to minimize memory leaks (optimize memory usage).
denisT.MaxDoctor
this is better version:
silentErrors:off
	local node, giz
	local source_mesh
	local target_mesh
		selected type:#boolean animatable:off ui:ui_selected
		group "Geometry: "
			checkbox ui_selected "Use Selected Vertices" offset:[0,8]
	tool create
			#stop
			this.clearGizmos()
			tvv = if selected then target_mesh.selectedverts as bitarray else #{1..target_mesh.numverts}
			svv = source_mesh.numverts
			for v in tvv where v <= svv do
				giz.startNewLine()
				p0 = getvert target_mesh v * target_tm
				giz.addPoint p0
				p1 = getvert source_mesh v * source_tm
				giz.addPoint p1
	on updateGizmos do
		makeMorphTracks()
gc()
delete objects
@denisT.MaxDoctor  Thank you very much!! Your script works perfectly! Just one last question: is it possible to draw arrows instead of simple lines? I'd be interested in knowing the direction of motion. Thank you again!
denisT.MaxDoctor
silentErrors:off
	local node, giz
	local source_mesh
	local target_mesh
		markers type:#boolean animatable:off ui:ui_markers
		source_marker type:#integer default:6 animatable:off ui:ui_source_marker
		target_marker type:#integer default:9 animatable:off ui:ui_target_marker
		local marker_types =
			"None",
			"Point", "Plus Sign", "Asterisk", "xMarker",
			"Dot", "Small Dot",
			"Small HollowBox", "HollowBox", "Big Box",
			"Small Circle", "Circle",
			"Small Triangle", "Triangle",
			"Small Diamond", "Diamond"
		group "Source: "
			label lb_source "Marker:" align:#left offset:[0,2] across:2
			dropdownlist ui_source_marker items:marker_types width:102 height:(marker_types.count+1) align:#right offset:[5,-2]
		group "Target: "
			label lb_target "Marker:" align:#left offset:[0,2] across:2
			dropdownlist ui_target_marker items:marker_types width:102 height:(marker_types.count+1) align:#right offset:[5,-2]
		group "Display: "
			checkbox ui_selected "Use Selected Vertices" offset:[0,0]
			checkbox ui_markers "Show Markers" offset:[0,0]
		fn getMarkerType index =
			if index > 1 and index <= marker_types.count do (substitutestring marker_types[index] " " "") as name
	tool create
			#stop
		line_color = yellow as point4
		mark_color = orange as point4
			this.clearGizmos()
			startline = giz.startNewLine
			addpoint = giz.addPoint
			addmarker = this.addGizmoMarker
			trg_mark = this.params.getMarkerType target_marker
			src_mark = this.params.getMarkerType source_marker
				startline()
				addpoint p0
				addpoint p1
				if markers do
					if trg_mark != undefined do
						addmarker trg_mark (p0 * node_tm) (gizmoActiveViewportOnly) mark_color mark_color
					if src_mark != undefined do
						addmarker src_mark (p1 * node_tm) (gizmoActiveViewportOnly) mark_color mark_color
	on updateGizmos do
		makeMorphTracks()
gc()
delete objects
From a performance point of view it is not good to draw arrows (extra shapes, extra calculations), it is easier and faster to use Markers ... This example shows how to do it
Thank you so much!!! This is perfect 🙂
