How to copy working pivot translation and rotation to local and world pivot?
holchangomes
holchangomes
-- Get the working pivot transformation matrix
workingPivotTM = WorkingPivot.getTM()
-- Set the pivot values to match the working pivot transformation matrix
$.pivot = [workingPivotTM[4][1], workingPivotTM[4][2], workingPivotTM[4][3]] -- Set pivot translation
I got the translation to work, but couldn't do it for the pivot rotation.
denisT.MaxDoctor
fn alignPivotToTM node tm =
	itm = tm * (inverse node.transform)
	node.transform = tm
	node.objectOffsetPos *= inverse itm
	node.objectOffsetRot *= inverse itm.rotation
	node.transform
alignPivotToTM $ (WorkingPivot.getTM())
holchangomes
The whole object moved, the pivot got where i want, but by rotating the entire object, not only just the pivot.
denisT.MaxDoctor
explain clearly what you want... give a picture or example that illustrates what you exactly need
holchangomes
Sure, i have a script(basachii) that takes an edge or 2 vertex and use this to align a working pivot, but now i want this aligned with a vertex/edge working pivot to be the local pivot too.
denisT.MaxDoctor
You are saying something that only you can understand... There is no such thing as a "local" or "global" pivot in 3DS MAX.
Let's try again... what and with what do you want to align?
