How to control object rotation speed by custom attribute with smooth rotation adjustments?
ViperAleks
Message 1 of 8
ViperAleks
I would like to control rotation of object (helicopter rotor) by a custom attribute parameter. Let say custom attribute parameter changes from 0 to 100. If custom attribute parameter is 0 then there is no rotation on helicopter rotor. If custom attribute parameter is 100 then helicopter rotor is at full rotation speed.  If I make a simple expression for rotation axis as Custom_Attribute_parameter*S  (where S is seconds) then it works fine while custom attribute parameter doesn't change over time. The problem arise when I need smoothly change rotation speed over time, like if helicopter rotor increasing or decreasing rotation over time. Because in my version rotation values change significantly over time depending on the current time, S parameter. Can someone give me a clue how to achieve a smooth rotation speed change in any time on timeline, please?
Replies (7)
Message 2 of 8
denisT.MaxDoctor
Actually, in MAX there is a multiplier curve for this...
Another option is to make a list controller with zero and max speed values, and use the second one's weight to control.
Message 3 of 8
ViperAleks
Thank you for your reply. I understood your second option and I will give it a try. But I am not sure what you mean by multiplier curve. Could you explain it, please?
Message 4 of 8
denisT.MaxDoctor
delete objects
b = box name:#blades width:100 length:10 height:3
ss = b.rotation.controller[3].controller = float_script()
ss.addconstant #max_speed 0.1
ss.setexpression "-max_speed * F"
power = bezier_float()
addMultiplierCurve ss power
t_0000 = addnewkey power 0
t_0000.value = 0
t_0050 = addnewkey power 50
t_0050.value = 1
t_0100 = addnewkey power 100
t_0100.value = 0
Message 5 of 8
denisT.MaxDoctor
If you still want CA:
delete objects
ca_speed = attributes ca_speed attribid:#(0x10101, 0xa0a0a)
	parameters params rollout:params
		speed type:#float default:0 animatable:on ui:ui_speed
	rollout params "Speed Control"
		spinner ui_speed "Speed:" type:#float range:[-1,1,0] scale:0.001 fieldwidth:60 align:#right
	on create do
		speed.controller = bezier_float()
custattributes.add b ca_speed baseobject:on
ss.addtarget "speed_val" b.baseobject.ca_speed[#speed]
ss.setexpression "-max_speed * F * speed_val"
Message 6 of 8
ViperAleks
Thank you again for your help. Unfortunately, I was not able to achieve expected result using power curve or expression. The main problem is that when I need to start rotation from 0 to some value and my animation is in frame 2000, for example, then I have a multiplier F (frames) as big value, and rotation jumps from 0 to the high degree suddenly. I cannot get smooth rotation start in this case. All these sudden rotation changes not noticeable during preview, but they are very noticeable during render with the motion blur.
Message 7 of 8
denisT.MaxDoctor
Your question concerned a technical solution, not an algorithmic one. Technically, I showed you how to do it... but from an algorithmic point of view, you need to control not the absolute value (as shown in my examples), but the relative value (delta) and add it to some initial value.
Message 8 of 8
ViperAleks
This is true. I came to conclusion that I have to play with current frame and next frame to adjust rotation speed. If I have a constant rotation speed then
next_frame_rotation_angle_delta  =  current_frame_rotation_angle_delta * 1
If I need to slow down rotation then multiplier should be < 1. If I need to increase rotation then multiplier should be > 1.
