How to access the WorkingPivot in Python?
Tupaia
Tupaia
Hello!
I have zero max script experience, but some with Python, from other 3d applications.
My goal is to write a simple Python script that activates the WorkingPivot and auto-aligns it to the Transform Gizmo, among other things.
Im max script, this activates the WP:
WorkingPivot.EditMode = true
However, I can't figure how to do the same in Python, not counting this:
MaxPlus.Core.EvalMAXScript("WorkingPivot.EditMode = true")
What's the 'clean' way of accessing Max' core interface functionality?
Thanks a lot!
Swordslayer
I'd use the pymxs.runtime MAXScript engine wrapper. For example, the sample of activating the working pivot mode you used would be:
pymxs.runtime.workingPivot.editMode = True
Tupaia
That's clean enough for me!
Thank you, Sir! 😃
denisT.MaxDoctor
i don't mess with Max Python, but it should be an API solution as well, where c++ is:
void SetWorkingPivotUseMode(BOOL use)
	IWorkingPivot* pvi = (IWorkingPivot*)(GetCOREInterface(IWORKINGPIVOT_INTERFACE));
	pvi->SetUseMode(use);
