How can I use a variable inside a modifier line?
m.ayed002
m.ayed002
I'm a complete newbie in this, I don't have have much programing knowledge just the basics and I'm just playing around trying to learn it and make buttons to help me save time doing some tasks that I find myself doing repetedly
I want to select the faces  (in edit poly) of the sides of a box no matter how many faces it have
so if a box is [n,m,L] I want to select {n*m*2+1 .. n*L*2+m*L*2}  <- lets call this w
I have been able to assign the variables n m and L using $.heightsegs $.widthsegs and $.lengthsegs
But I can't use them inside the modifer like this ( $.modifiers[#Edit_Poly].Select #Face #{w} )
It would be a huge help if anyone can help me with this, I attached my file just in case
Thanks 🙂
Swordslayer
if isKindOf $ Node and isKindOf $.baseobject Box and isValidObj $.modifiers[Edit_Poly] do
	local n = $.baseobject.widthsegs
	local m = $.baseobject.lengthsegs
	local L = $.baseobject.heightsegs
	local w = #{n * m * 2 + 1 .. n * m * 2 + n * L * 2 + m * L * 2}
	w.count = $.modifiers[Edit_Poly].GetNumFaces() -- SetSelection only works if the bitarray lenght matches the total number of verts/edges/faces
	$.modifiers[Edit_Poly].SetSelection #Face w
m.ayed002
Thanks alot! It makes sense!
if isKindOf $ Node and isKindOf $.baseobject Box and isValidObj $.modifiers[Edit_Poly] do : What does this sentence mean in normal language?
I tried looking up those in the documentation of maxscript but is too general and not very easy to work with
I'll go try this now 😄
m.ayed002
It worked for me with just this 🙂
	on Dont_Touch_Before_setting_up_a_box changed val do
		modPanel.addModToSelection (Edit_Poly ()) ui:on
			subobjectLevel = 4
		$Box.modifiers[#Edit_Poly].Select #Face w
		$Box.modifiers[#Edit_Poly].SetOperation #Inset
		$Box.modifiers[#Edit_Poly].insetType = 1
		$Box.modifiers[#Edit_Poly].insetAmount = 0.15
		$Box.modifiers[#Edit_Poly].Commit ()
Now I will try to the inset amount a changeable variable and add more options (texturing and other operations)
I'm trying to make a low poly building generator in case anyone is wondering, for now I'm trying the easiest which is a simple glass skyscraper
