How can i Create Sub-Objects in By modifier and Display it?
Hello^^
I am making a modifier, this modifier shoud have some sub-Object which Display somthing like a Cylinder or Sphere,
Can Modifier have a Sub-Object like the ProcedualObject?
and how can i do that?
how can i dispaly that?
And
threre are something used in SimpleMod::GetWorldBoundBox() without description. I Couldn't Understand this.
this is DoModifiedBox(*mc->box, GetDeformer(t,*mc,invoff,off), bp1);
And Would you explain about Clipping machanism and Way of Displaying Sub-Objects well?
digginc
Could you explain in a bit more detail what you are trying to do? I am not sure what you mean by a modifier having a sub-object. Perhaps you mean that when he modifier is applied, it creates a new scene object? In whatever circumstance you are you should be able to create a 3ds Max primitive object (such as a cylinder or sphere) using the API call:
virtual void* Interface::CreateInstance(SClass_ID superID, Class_ID classID)=0; //Maxapi.h
This is covered in the topic "Object Creation Methods" in the Max SDK CHM.
Does this help?
Christopher Diggins, M&E SDK Specialist
For 3ds Max SDK questions also check out http://stackoverflow.com/questions/tagged/3dsmax
