HLSLMaterialHandle.SetTextureParameter() dont work ?
kevin.kelley
kevin.kelley
Why don't this code work, all i get is black material on a simple plane, i have spent 2 days trying to solve this.
Project I am using is "howto\Graphics\HLSLShaderMaterials"
Just trying to simply set a texture in the shader.
HLSLMaterialHandle handle = GetHLSLMaterialHandle(featureLevel);
TextureHandleUtility::CreateTextureHandle(Texmap*, TimeValue);
handle.SetTextureParameter (_M("texture_name_in_fx_file"), hTexture);
"Texmap*" is valid, the material handle is valid and i can set 'float' values.
No errors when the shader compiles.
Ive tested the shader.fx in a 'DirectX Shader' material, it works and renders textures correctly.
kevin.kelley
I can not get HLSLMaterialHandle.SetTextureParameter() to update a texture, is this method not implemented by the interface ?
I have found a work around, I have tested IDX9DataBridge and can set/update textures through IHardwareMaterial.
