Hiding struct fields from call stack printer on error
Hi guys!
I've got a MAXScript tool that uses structs with inherited methods and other structs with their own methods...
And I've got a HUUGE problem: as a runtime error occurs, MAX tries to print the call stack, and it takes a VERY long time, like I'm just waiting near a half of hour to simply see the error text(I don't really need the call stack often, and I can store it manually if i wish to).
So, the questions're:
1) How can I "hide" struct members to make them not be printed, or can I kinda turn off call stack display? I know about "private" member definition, but it won't work in 3D MAX 9 SP 2, that I must support in my script.
2) How can I break the script execution? I mean like a result of an error throw - the script just stops all work and returns at the top level of the call stack.
In general not sure why would you need such huge structs. Maybe consider splitting it?
However, you can avoid printing stack info when you handle exception like:
try
  filein "some_script.ms"
catch
  format "*** % ***\n" (getCurrentException())
For stopping your maxscript at any point just call throw() (in your case it would be a good idea to handle it)
Hope it helps,
My structs're splitted, but they inherit one another - that's why the original problem appears.
I know how to handle errors, and I'm very interested to see the call stack with parameters in the handler, but I can't(see the original problem).
Well, in this case I suppose I can't help you.
I would recommend considering turning your tool (or parts) into C++ or C# plugin if you need such massive data structures.
Also you should gain some performance and powerful debugging tools.
