Hiding all the references plans layers
Hello, somebody could help me?
I try to develop a maxscript very simple but I don't understand definitely maxscript.
The purpose is to make a simple script which can hide all the layers who's name begin by "ref".
For example an active/inactive button which can show/hide all the "references plans" with similar names as:
"ref layer a"
"ref layer b"
"ref layer c"
For now, I just have this part of code but it's just hiding the layer named "ref" and not all the layers with "ref" in the name:
(layerManager.getLayer 0).current = true
rfp= "ref"
for L = 1 to LayerManager.count do
layer = (LayerManager.getlayer (L-1))
if layer.name == rfp then layer.ishidden = true
Thanks for advance for your help!
Maybe this is what'll do teh trick?
-- Toggle layer visibility
fn tglLayer prefix splitChar:" " =
local mng = layerManager
for i = 1 to mng.count - 1 where (filterstring (local layer = mng.getLayer i).name splitChar) == prefix do
if layer.isHidden then
layer.isHidden = False
else
layer.isHidden = True
tglLayer "ref" splitChar:" " -- where layer name is similar to "ref blah blah"
tglLayer "ref" splitChar:"_" -- where layer name is similar to "ref_blahdi_blah"
splitChar is basically the search string for filterString()
if splitChar is unsupplied it defaults to using " " which is what YOU want it seems =)
BR
MrK
Edit: Made layer var local
WOW !!! What's a GREAT place !
Thanks a lot for this function and for your quickly help !
