Help to improve performance when reading large files
blakestone
Message 1 of 12
blakestone
Back again... I am reading an XML file which is 15,000+ lines (~280MB) where I need to check lines for keywords and collect its data. Currently it's taking ~8 minutes to read this file which I am hoping to reduce this to anything less. Any ideas would be greatly appreciated!
Here is an example of how my script looks
local my_file = "c:\\my_file.xml"
local my_fileOpen = undefined
local my_fileRead = undefined
local my_array = #()
-- open file
my_fileOpen = openFile my_file
-- read file (line-by-line)
while not eof my_fileOpen do
my_fileRead = readLine my_fileOpen
if (matchPattern my_fileRead pattern:"*<node>*") then append my_array my_fileRead
-- close file
close my_fileOpen
print my_array
Replies (11)
Message 2 of 12
barigazy
Look this threat to see how to read from xml
Message 3 of 12
blakestone
This is great for an XML but what about non-XML files... as per the title "when reading large files" ?
Message 4 of 12
Steve_Curley
Have a look at the MemStream interface. It loads the entire file into memory in one go which is obviously a lot faster than repeated calls to the OS to read a line at a time.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 5 of 12
blakestone
memStream == awesome........... I got this process from ~8 minutes down to 2.5 seconds!
local my_memOpen = undefined
local my_memRead = undefined
-- open memStream
my_memOpen = memStreamMgr.openFile my_file
-- read file &#40;line-by-line&#41;
while not my_memOpen.eos() do
my_memOpen.skipSpace()
my_memRead = my_memOpen.readLine()
if (substring my_memRead 1 7) == "&lt;layer&gt;" then append my_array my_memRead
-- close memStream
memStreamMgr.close my_memOpen
print my_array
Message 6 of 12
Steve_Curley
I take it you're happy then? 😉
Max 2016 (SP1/EXT1)
Message 7 of 12
blakestone
I am very happy, thanks again for your assistance!
You wouldn't know how to speed up
importFile
would you, I am importing 100+ objects one after another and yeah it's a slow process. About 2 minutes for 100 objects.
Message 8 of 12
Steve_Curley
You're quite welcome 🙂
ImportFile&#40;&#41; I doubt can can be sped up at all. Each filetype is probably already optimised - when you consider everything that the import has to do, from reading the file through to reconstructing the mesh and the UVs and the materials and so on, 2 mins for 100+ objects is probably not bad.
Try manually importing one and time the actual import - even if it only takes a second that's 100 secs or 1:40 for them all. Larger objects will take longer, obviously. I suspect that reading the file is not the bottleneck, it's everything else which has to happen.
Max 2016 (SP1/EXT1)
Message 9 of 12
blakestone
a random thought... can i run importFile multiple times instead of 1 at a time?
Message 10 of 12
Steve_Curley
Under script control? Don't see why not.
Create a simple text file with the necessary details - filename, import type, object name (if applicable) then just read that a line at a time (using memStream of course 😉 ) and set up the import for each one. Would that help?
Max 2016 (SP1/EXT1)
Message 11 of 12
blakestone
I am not sure how that would be much faster than what I am currently doing... I can visually see the delay with the importing process via its progress bar. I think the key here is to kick off the import process without pausing the script so that I can execute one after another without waiting for the previous one to finish.
Can you force the script to continue after executing importFile or maybe I could generate some maxscript files and then kick them off using the HiddenDOSCommand doNotWait:true
Message 12 of 12
Steve_Curley
I'm not sure about not waiting for a command to complete - I don't think so, and as most of Max is not multi-threaded you could give it, and yourself, a real headache.
As for using DOS's doNotWait - that would mean running multiple copies of Max (I think), which besides being slow would eat up memory at a rate of knots.
Max 2016 (SP1/EXT1)
