Announcements
GUI Progress not updating... because (Not Responding)
blakestone
blakestone
I have used the Progress in a number of MAXScript GUI windows and it updates successfully however many times when executing a script the GUI window sits there showing (Not Responding) rather than update the GUI such as the Progress or updating Label etc.
The script has not failed and just does not update the GUI due to the (Not Responding).
In the below example you can see it gets about 10% in then shows (Not Responding) and then finishes. Any ideas?
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
barigazy
See all links of these CGTalk thread
blakestone
Fixed, Thanks... for those who want the code:
fn DisableProcessWindowsGhosting = (
if classof (dotnet.GetType "DisableWindowsGhosting") != dotNetObject do (
local source = StringStream ("using System.Runtime.InteropServices; public class DisableWindowsGhosting{ public static extern bool DisableProcessWindowsGhosting();}")
compilerParams = dotnetobject "System.CodeDom.Compiler.CompilerParameters"
compilerParams.ReferencedAssemblies.Add("System.dll");
compilerParams.GenerateInMemory = on
csharpProvider = dotnetobject "Microsoft.CSharp.CSharpCodeProvider"
compilerResults = csharpProvider.CompileAssemblyFromSource compilerParams #(source as String)
flush source
close source
if (compilerResults.Errors.Count > 0 ) then (
local errs = stringstream ""
for i = 0 to (compilerResults.Errors.Count-1) do (
local err = compilerResults.Errors.Item
format "Error:% Line:% Column:% %\n" err.ErrorNumber err.Line err.Column err.ErrorText to:errs
format "%\n" errs
undefined
else (
compilerResults.CompiledAssembly.CreateInstance "DisableWindowsGhosting"
barigazy
That code you must save as *.ms and place it in maxroot/scripts/startup directory
