GetUVGen() for CHECKER_CLASS_ID
istan
Advisor Advisor
Message 1 of 15
istan
auto tmap = (::Texmap *) ip->CreateInstance( TEXMAP_CLASS_ID, Class_ID( CHECKER_CLASS_ID, 0 ) );
BitmapTex * bmt = dynamic_cast<BitmapTex *> ( tmap );
StdUVGen * uv = bmt->GetUVGen();  // <<< FAILS!
I need access to "StdUVGen" but have no idea, how to get the pointer for a checker map.
All the samples just show it for a Bitmap map.
Replies (14)
Message 2 of 15
denisT.MaxDoctor
I confirm the failure.
Well... use the GetTheUVGen method of the Texmap class.
Message 3 of 15
denisT.MaxDoctor
Why do you cast Checker to BitmapTex? It doesn't seem right...
But as I mentioned earlier, BitmapTex::GetUVGen doesn't work for me.
Message 4 of 15
denisT.MaxDoctor
You can cast after that:
	if (auto tex = (Texmap*)max_ip()->CreateInstance(TEXMAP_CLASS_ID, Class_ID(CHECKER_CLASS_ID, 0)))
		UVGen* uvgen = tex->GetTheUVGen();
		StdUVGen* uvstd = dynamic_cast<StdUVGen*>(uvgen);
Message 5 of 15
klvnk
you can't cast  a Checker map to a BitmapTex and expect it to work 🙂
do it this way...
Texmap *checkerMap = (Texmap *) CreateInstance(TEXMAP_CLASS_ID, Class_ID(CHECKER_CLASS_ID,0));
	StdUVGen *uvGen = (StdUVGen*)checkerMap->GetTheUVGen();
to be precise you should get a UVGen first, then check to see it thats a StdUVGen with UVGen::IsStdUVGen () then cast to StdUVGen, but hey ho 😄
Message 6 of 15
A012255
You are right. This is it:
StdUVGen * uv = (StdUVGen *) tmap->GetTheUVGen();
Message 7 of 15
A012255
Thanks to everybody!
Message 8 of 15
denisT.MaxDoctor
We worked in parallel... 😉
It seems like the direct GetUVGen method BitmapTex is not functioning properly.
Message 9 of 15
klvnk
I checked it in our exporter seems fine if it is an Actual BitmapTex
Message 10 of 15
denisT.MaxDoctor
My understanding is that GetTheUVGen returns StdUVGen in general... otherwise dynamic_cast should not have worked. Wouldn't it?
Message 11 of 15
istan
UVGen* uvg0 = tex->GetTheUVGen();
if (uvg0 && uvg0->IsStdUVGen()) {
	StdUVGen *uvg = (StdUVGen*)uvg0;
	uvg->InitSlotType(MAPSLOT_ENVIRON);
	uvg->SetCoordMapping(UVMAP_SPHERE_ENV);
Look at this code snippet from the examples. IMHO it's self explaining (if it's working).
For me all clarified. Thank you Denis & klvnk.
Message 12 of 15
denisT.MaxDoctor
Here is what the header says:
virtual BOOL IsStdUVGen() { return FALSE; } // class StdUVGen implements this to return TRUE
virtual (!)
The question is: if it's not StdUVGen, what is it? The documentation mentions either StdXYZGen or a custom 🤣
Message 13 of 15
klvnk
a custom implementation that derives from UVGen that returns false from IsStdUVGen
Message 14 of 15
denisT.MaxDoctor
Yes. What is about StdXYZGen?
Message 15 of 15
denisT.MaxDoctor
Haha! I found how easy to crash the MAX:
meditmaterials[1] = c = checker()
c.coords = StandardXYZGen()
... and try to open the Material Editor 😜
but for texmaps those need StdXYZGen it's safe:
meditmaterials[2] = d = dent()
d.coords = StandardUVGen()
PS. No! Both setting UV in place of XYZ or XYZ in place of UV will cause MAX to crash
This is interesting because I can't find a way to check what type of Map Coordinates a texture map class needs.
