Announcements
Getting error -- Syntax error: at ;, expected <factor> -- In line: )
dawoodmuhamm
dawoodmuhamm
Community Visitor
Community Visitor
this is the script [attached] I have been running when it asks me to select the folder I select it after that it gives me this error. -- Syntax error: at ;, expected <factor> -- In line: )
dmitriy.shpilevoy
I think returns in the beginning causing it. Because it is outside of function maybe?
You can run this and will get same error
if 2 == 2 then
messageBox "No 3ds Max files were found in the directory!"
return
jeff
I am not a script expert... but,
It might be in this and similar code sections?
 if (baseBone1 == undefined) then
        messageBox ("Base bone Bip01 not found in file: " + files[fileIndex])
        continue
    -- Select all bones connected to base bone Bip01
    selectBones "Bip01"
    exportNumber = "1"
My first impression is that even if bone "Bip01" does not exist, you are still trying to select "Bip01". Does the scrip work if all the messageBox conditions are satisfied?
Max since 1992 (3d Studio) · Win 10-64 · Wintel workstation · 64 GB RAM · nVidia Quadro RTX 4000 · BB render garden via Deadline
