Get selected Layer
Get selected Layer
elpie89
Get selected Layer
elpie89
I'm using the dialog displayed by
Global.COREInterface14.DoHitByNameDialog(null);
I would like to retrieve the list of Selected Layers in that panel
Is it possible? I can't find any way.
Do you have some advice?
thanks
istan
This is the standard node selection dialog, returning you a list of nodes, or?
Why don't you then iterate on the selected nodes with
GetLayerFromNode()
to get all affected layers?
denisT.MaxDoctor
GetLayerFromNode()
usually when anyone asks about "selected layer", it means a layer selected in Layer Manager. In this case it might be a situation when no one node is selected but a layer is
elpie89
Thanks @denisT.MaxDoctor to explain that.
You get the point...yes I need only the layers selected in the layer manager
denisT.MaxDoctor
so "layer selection" makes sense only when Layer Explorer is open.
You have to find Layer Manager Dialog as .net control. Find the TreeList which is SceneExplorerTreeList.
It's an expension of DevX XtraTreeList.
To get selected nodes use Selection property.
To get the count  XtraTreeList.Selection.Count
To get a node XtraTreeList.Selection.get_item(<0 based index>)
To get a node name (the Layers's name)  XtraTreeList.Selection.get_item(n).GetValue 0
i'm prety sure the MAX provides easy access to Layer Explorer dialog. But i don't forgot how and not really interested right now to remember 🙂
elpie89
I still struggling on this, I was out the entire week actually.
So after a day, I figured out a there is a bunch of dll that I should use for this task
https://help.autodesk.com/view/3DSMAX/2017/ENU/?guid=__files_GUID_A08A117C_9D15_4044_BC29_3AD9F8AFD9...
and I found some documentation here
http://download.autodesk.com/global/docs/3dsmaxsdk2012/en_us/index.html?url=dotnet_ref/class_max_cus...
I can't found the same page for max 2019
Anyway, my problem now is that I can't find the famous SceneExplorerTreeList.
it should be in some method of SceneExplorer.dll
I'll probably find it tomorrow but if you have some info please let me know.
You already helped a lot redirecting me to the right classes
elpie89
I found a way:
private SceneExplorerDialog sceneExplorer;
if (!sceneExplorer.Visible)
sceneExplorer.Closed += SceneExplorerOnClosed;
sceneExplorer.Show();
private void SceneExplorerOnClosed(object sender, EventArgs e)
TraversalNode[] traversalNodes = sceneExplorer.ExplorerControl.GetSelectedNodes(false, false, false);
foreach (TraversalNode traversalNode in traversalNodes)
if (INodeUtilities.IsMaxLayerTraversalNode(traversalNode))
ITraversalILayer layer = (ITraversalILayer) traversalNode;
MessageBox.Show(layer.SceneName);
and of course, the name of the layer is accessed with layer.SceneName
make sense😂
Thanks a lot
