Get keyframes of background bitmap's Cropping/Placement UV - maxscript
I'm using 3Ds Max 2016.
I need to get keyframes of background bitmap image's cropping/placement UV.
I can access background bitmap via scenematerials or useEnvironmentMap.
Is it possible to get required keyframes from the bitmap object?
Thank  you!
Swordslayer
All the animatable parameters expose .keys property, you can query it directly, for example:
<textureMap>.clipU.keys
As for the properties themselves, short of checking the BitmapTexture : TextureMap chapter, the easiest way to get the name of the parameter you want to query is to activate MacroRecorder and change the value.
