get and set to Ini
get and set to Ini
get and set to Ini
Hi
I'm looking into a script that resets the Dialogpos. of the Material Editor, Curve Editor &
the RenderDialog. (When you have a dual monitor setup and change the virtual position of
you secondary monitor, Dialogs are left behind.)
I can find the position of 'Select Objects' dialog, but nothing else:
getinisetting "C:\etcetc\Application Data\Autodesk\3dsmax\9 - 64bit\enu\3dsmax.ini"
"DialogResizer_SizeAndPositions" "SelectObjectsDialog"
Does anyone know where to find it?
BR,
Aplomo
Same file: 3dsmax.ini, try to search for "Position", you should be able to find them . Curve Editor stays with the main Max window AFAIK.
Cheers,
--Nam
Thanks!
It works for the RenderDialog but not for the materialbrowser.
This is my first test:
macroscript Resetter category:"TT_Tools"
global inidir64 = "C:\yada\9 - 64bit\enu\3dsmax.ini"
global inidir32 = "C:\yada\9 - 32bit\enu\3dsmax.ini"
global reser()
global dialogarray = #("MaterialBrowserDialogPosition","RenderDialogPosition")
rollout ReSetIt "ReSetIt"
button reset_btn "Reset Dialogs"
fn reser =
if is64bitApplication() == true then
setIniSetting inidir64 dialogarray "Dimension" "1 1 355 1045"
completeRedraw()
else
setIniSetting inidir32 dialogarray "Dimension" "1 1 355 1045"
on reset_btn pressed do
reser()
createDialog ReSetIt
I also want to check to see if the Dialogs are open and if so, close them.
Does anyone know why this doesn't work with the materialeditor the way I've written it?
BR,
Aplomo
Hi Aplomo,
Material Editor position should be under
Are you looking for <bool>MatEditor.isOpen()? and renderSceneDialog.isOpen()
Hope this helps,
--Nam
Thats the one!
I really should do more research before posting 🙂
Thanks alot NamNguyen!..
Edit: For those interested here's the script.
global inidir = getMAXIniFile&#40;&#41;
global reser(&#41;
global closedd = #(MatEditor,RenderSceneDialog&#41;
global dialogarray = #("MtleditorPosition","RenderDialogPosition")
global Varoptions = #("MainWindow","Dimension")
global DPos = "1 1 400 600"
global checknclose()
fn reser =
for i in 1 to dialogarray.count do
setIniSetting inidir dialogarray Varoptions DPos
completeRedraw()
closedd.open()
fn checknclose =
for i in 1 to closedd.count do
if closedd.isOpen() == true then closedd.close()
rollout ReSetIt "ReSetIt" width:112 height:40
button reset_btn "-- Reset --" pos: width:82 height:24
button q_btn "?" pos: width:16 height:24
on q_btn pressed do messagebox("Resets your MtlEditorDialog and RenderDialog")
checknclose()
reser()
Could this be done much easier? I suspect so.... 🙂
Let me know!
BR,
Aplomo
