FloatScript by maxscript
Im trying to setup a script wich will create a float_script controller for object rotation, but I have some problem with addTarget option. So I have a cylinder wich will have the script on x rotation, and I have a point helper wich is path_constrainted to a line, what I need is to addTarget of the percent of that point helper, my code look like this :
                    fs = float_script ()
                    o.rotation.controller.X_Rotation.controller = fs
                    fs.addTarget "Percent" mainCnt.position.controller.Percent
When I evaluate this script it throws me a error:
Runtime error: IScriptCtrl::AddTarget - Target needs to be object or subAnim, got: 0.0
Anyone can help?
istan
if you evaluate this line:
what is it reporting ?
Did you find this example in the doc ?
obj1 = Teapot ()--Create a teapot
-->$Teapot:Teapot001 @ [0.000000,0.000000,0.000000]
obj2 = instance obj1--Create an instance
-->$Teapot:Teapot002 @ [0.000000,0.000000,0.000000]
obj2.pos = [-100,0,0]--Place the instance 100 units along -X
-->[-100,0,0]
obj3 = Box pos:[100,0,0]--Create abox 100 units long X
--> $Box:Box001 @ [100.000000,0.000000,0.000000]
ctrl = float_script()--Create aFloat Script Controller
-->Controller:Float_Script
obj3.height.controller = ctrl--Assign Controller to Height of Box
ctrl.addTarget "myTeapot" obj1[4]--Add Target Var. with Teapot Obj.
-->true
ctrl.setExpression "myTeapot.Radius"--Set Height to Teapot Radius
-->true
ctrl.getTarget "myTeapot"--Get the Target Track as SubAnim value
-->SubAnim:Object__Teapot
ctrl.getTarget "myTeapot" asObject:true--Get as Object
-->Teapot
ctrl.PrintDetails()--Print the controller details
-->"** Script Control Details **
-->* Description:
-->(null)
-->* Expression:
-->myTeapot.Radius
-->* Variables
-->Members: 5
-->01) T, Constant = 16000.0
-->02) S, Constant = 3.33333
-->03) F, Constant = 100.0
-->04) NT, Constant = 1.0
-->05) myTeapot, Track: $Teapot001.'Object (Teapot)', tick offset = 0
Thanks for reply, I've seen this before, but mayby Im wrong. In float_script window there is a four buttons =
Assing Constant
Assing Controller
Assign Track
Assign Node
What I need is Track, but when I try:
$.rotation.controller.X_Rotation.controller.addTrack it throws me a error "unknow property". Manually I can assign the percent of Point on path_constraint by clicking AssignTrack, but how to do it in maxscript?
denisT.MaxDoctor
check the mxs help for right syntax:
delete objects
with redraw off
	s = point name:#source wirecolor:orange axistripod:on box:on
	t = dummy name:#target
	c = circle radius:100
	pc = t.position.controller = path_constraint path:c
	ps = s.rotation.controller.z_rotation.controller = float_script()
	ps.addtarget "Percent" pc[#percent]
	ps.setexpression "(Percent*0.01) * (2*PI)"
AddTarget requires a subAnim (not a controller, not a Value)
