Finding when a new object is created
I would like to basically intercept any new objects as they're created and assign it a custom type. So I was wondering if there was a callback or something I could use instead of looping and checking for a new object in the scene every frame.
Yes you should be able to do that - there are callbacks you can set up.
You'll want to look up info on NOTIFY_NODE_CREATED and
int RegisterNotification(NOTIFYPROC proc, void *param, int code);
Mike
