File dialogs
File dialogs
File dialogs
Hello, I`m creating simple dialog for my 3DXI exporter, so i want specify some specific folders and I`m trying to show DoMaxBrowseForFolder
INT_PTR CALLBACK ExportOptionsDlgProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam)
switch(message) {
case WM_COMMAND:
switch (LOWORD(wParam))
case IDC_BTN_MESH:
pathControl = IDC_PATH_MESH;
initPath = params.m_meshPath;
Interface13* imax = GetCOREInterface13();
imax->DoMaxBrowseForFolder(hWnd, _M(""), initPath);
The dialog is showing, but buttons or other controls don`t work, I've tried pass NULL or MaxhWnd as hWnd to DoMaxBrowseForFolder.
I've checked in the debugger that the threads locks in NtPeekMessage, may be i have specify something?
Here i'm creating dialog:
if (!suppressPrompts && !DialogBoxParam(hInstance, MAKEINTRESOURCE(IDD_PANEL), pInterface->GetMAXHWnd(), ExportOptionsDlgProc, (LPARAM)(LPVOID)this))
return 1;
Is it OK that parent for FolderDialog also dialog?
MaxSDK 13.
I've tried a lot of things, but, unfortunately without success.
The exception still occur.
Here a code of FileDialog creation:
MSTR title = _M("Save as File"), _fname = _M(""), _path = _M("");
FilterList filterList;
imax->DoMaxSaveAsDialog(imax->GetMAXHWnd(), title, _fname, _path, filterList));
In the samples the code is same, i don't know why my isn't work.
Here is exception:
Unhandled exception at 0x0000000140496249 in 3dsmax.exe: 0xC000041D: An unhandled exception was encountered during a user callback.
Here is a callstack
  3dsmax.exe!0000000140496249()
3dsmax.exe!000000014049d24c()
3dsmax.exe!00000001400fd819()
> MyExport_x64.dle!ExportOptionsDlgProc(HWND__ * hWnd, unsigned int message, unsigned __int64 wParam, __int64 lParam) Line 139 + 0x95 bytes C++
user32.dll!UserCallDlgProcCheckWow() + 0x11b bytes
user32.dll!DefDlgProcWorker() + 0xba bytes
user32.dll!DefDlgProcW() + 0x36 bytes
user32.dll!UserCallWinProcCheckWow() + 0x11d bytes
user32.dll!CallWindowProcAorW() + 0x78 bytes
user32.dll!CallWindowProcW() + 0x18 bytes
uicontrols.dll!000000002e804633()
user32.dll!DispatchClientMessage() + 0x5f bytes
user32.dll!__fnDWORD() + 0x2d bytes
ntdll.dll!KiUserCallbackDispatcherContinue()
user32.dll!ZwUserMessageCall() + 0xa bytes
user32.dll!SendMessageWorker() - 0x3118 bytes
user32.dll!SendMessageW() + 0x5d bytes
comctl32.dll!Button_ReleaseCapture() + 0x157 bytes
comctl32.dll!Button_WndProc() + 0xcde bytes
uicontrols.dll!000000002e80432b()
user32.dll!DispatchMessageWorker() + 0x12a bytes
user32.dll!IsDialogMessageW() + 0x102 bytes
user32.dll!DialogBox2() + 0x174 bytes
user32.dll!InternalDialogBox() + 0x111 bytes
user32.dll!DialogBoxIndirectParamAorW() + 0x56 bytes
user32.dll!DialogBoxParamW() + 0x66 bytes
MyExport_x64.dle!IsolationAwareDialogBoxParamW(HINSTANCE__ * hInstance, const wchar_t * lpTemplateName, HWND__ * hWndParent, __int64 (HWND__ *, unsigned int, unsigned __int64, __int64)* lpDialogFunc, __int64 dwInitParam) Line 640 + 0x33 bytes C++
MyExport_x64.dle!EngineExport::DoExport(const wchar_t * name, ExpInterface * pExpInterface, Interface * pInterface, int suppressPrompts, unsigned long options) Line 190 + 0x4b bytes C++
Help please. Is there any examples except standart from SDK?
