fetch dynamic array of node pointers in SDK
How would you handle a fetch of node pointers to use later?
int N_Count = ip->GetSelNodeCount();
INode *MyNodes;
MyNodes = new INode[N_Count];
for (int i = 0; i < ip->GetSelNodeCount(); i++){
	MyNodes[i] = ip->GetSelNode(i);
It depends if you expect any changes in scene structure between your calls.
If the scene will not change than it should be fine, though you might consider INodeTab for this.
Otherwise it's best to store Animatable::GetHandleByAnim and get INode* back with Animatable::GetAnimByHandle (just test if it's not NULL, like for deleted nodes).
Hope it helps.
Got it, someone sent me some samples....
////INodeTab way
INodeTab nodes;
for (auto i = 0; i < ip->GetSelNodeCount(); ++i)
      nodes.AppendNode(ip->GetSelNode(i));
or
//// MaxSDK::Array
MaxSDK::Array<INode*> nodes;
      nodes.append(ip->GetSelNode(i));
or
////std::vector
std::vector<INode*> nodes;
      nodes.push_back(ip->GetSelNode(i));
 All work well.
