extrude code is not work ~~
anycganycgJ8A6A
Message 1 of 13
anycganycgJ8A6A
i made this code ~~
but not work  in many objects
and that is not extruded
what problem ~~~
for o in selection do
max create mode
converttosplineshape o
oo=copy o
sx=random 0.2 0.5
sy=random 0.1 0.5
oo.pivot=oo.center
oo.scale.x=sx
oo.scale.y=sy
converttopoly oo
gg=7000
addmodifier oo (shell outeramount:gg inneramount:0 )
p=random o.max o.min
oo.pos=p
louban_mat oo
converttopoly oo
select oo
subobjectlevel=4
polyop.setfaceselection oo 1
oo.insetAmount = 200
oo.EditablePoly.buttonOp #Inset
oo.extrusionType = 0
oo.faceExtrudeHeight = -600
oo.EditablePoly.buttonOp #Extrude
subobjectlevel=0
clearselection()
redrawviews()
Replies (12)
Message 2 of 13
blakestone
Your code works however only for Geometry objects - it's possibly failing when trying to perform a step on a Non-Geometry object or a Geometry object which has nothing in it i.e. no vertices, polygons etc.
The following adjustment will only allow the script to perform the steps on valid geometry objects.
    max create mode
    for o in selection where (superClassOf o == GeometryClass) do (
        --converttosplineshape o
        oo=copy o
    -- convert object to editable poly
        convertToPoly oo
    -- check if copied object has any vertices
    -- if not then delete copied object and skip to next selected object
        if (oo.verts.count == 0) then (
            delete oo
            continue
        sx=random 0.2 0.5
        sy=random 0.1 0.5
        oo.pivot=oo.center
        oo.scale.x=sx
        oo.scale.y=sy
        converttopoly oo
        gg=7000
        oo.pos=p
        --louban_mat oo
        converttopoly oo
        select oo
        subobjectlevel=4
        subobjectlevel=0
        clearselection()
        redrawviews()
Message 3 of 13
anycganycgJ8A6A
i tested that code
but that is not work well
pls select  many object ~~~
only worked  1 object
and not extrude~~~
Message 4 of 13
blakestone
This script works in my scene - I would like to see your scene to know why this is not working for you.
Can you please send me your scene so I can see what is causing it to fail.
Message 5 of 13
anycganycgJ8A6A
i  test it  in other  computer
but same error
i use  max 2013
see attached max file~~
Message 6 of 13
blakestone
Ok, I have made a few modifications and it's now working with the scene you provided.
	with undo on (
		local list = for o in selection where (superClassOf o == GeometryClass) collect copy o
		max modify mode
		for o in list do (
			select o
			convertToPoly o
			if (o.verts.count == 0) then (
				delete o
				continue
			o.pivot = o.center
			o.scale.x = random 0.2 0.5
			o.scale.y = random 0.1 0.5
			addmodifier o (shell outeramount:7000 inneramount:0)
			o.pos = random o.max o.min
			convertToPoly o
			subObjectLevel = 4
			polyop.setFaceSelection o 1
			o.insetAmount = 200
			o.extrusionType = 0
			subobjectlevel = 0
			update o
			clearSelection()
		forceCompleteRedraw()
Message 7 of 13
anycganycgJ8A6A
really  thank you  ~~~
but there is   2 problem ~~~
sorry my many ask ~~~
1.  if you see attched image .    object  random  z move
     created object     will become  z.0
2. if i  100 numbers object select , that  very slow
pls     can you  modify   that  that is not created in modify mode ~~
Message 8 of 13
blakestone
The following script will be dramatically faster - it took about 10 seconds to do 1000+ objects on my little laptop. This method is performing the steps on all valid objects as once, in addition to this I have disabled "undo" which also greatly assists with speeding up scripts.
    with undo off (
        local sel = for o in selection where (superClassOf o == GeometryClass) collect convertToPoly(copy o)
        local list = for o in sel where (o.verts.count > 0) collect o
        max modify mode
        clearSelection()
        select list
        for o in selection do (
            o.pivot = o.center
            convertToPoly o
            subObjectLevel = 4
            o.insetAmount = 200
            o.extrusionType = 0
            subobjectlevel = 0
        clearSelection()
Regarding problem #1 - are you wanting the Z coordinates to be 0 or a random number?
Message 9 of 13
anycganycgJ8A6A
yes~~
i want z 0
i attached my wanted image
Message 10 of 13
blakestone
This will set Z to zero.
	with undo off (
		local rand
		max modify mode
		clearSelection()
		select list
			o.pivot = o.center
			rand = random o.max o.min
			rand.z = 0
			o.pos = rand
			convertToPoly o
			subObjectLevel = 4
			o.insetAmount = 200
			o.extrusionType = 0
			subobjectlevel = 0
		clearSelection()
Message 11 of 13
anycganycgJ8A6A
work well
but inset not apply ~~~
sorry sorry  and thank you kindly reply~~~~
pls see my attached image
Message 12 of 13
blakestone
Yes the 'inset' is not working because these steps and simulated button presses can not be performed on a selection of objects they need to be done one-by-one. Splitting up the code like I have below allows you to perform these steps on the selection and one-by-one. This is still quite a slow process and for 1000+ objects will take several minutes.
If time is a real issue here then I would suggest approaching this differently, instead of constructing these objects via script - build a modular template and simply use script to postion, scale it etc.
	with undo off (
		local rand
		max modify mode
		clearSelection()
		select list
			o.pivot = o.center
			rand.z = 0
			o.pos = rand
			convertToPoly o
		for o in list do (
			clearSelection()
			select o
			subObjectLevel = 4
			o.insetAmount = 200
			o.extrusionType = 0
			subobjectlevel = 0
		clearSelection()
Message 13 of 13
anycganycgJ8A6A
wow good ~~~~
rellay really thank you
if that is slow , like you said  i will think other aprroach~
really really thank you ~~
again  rellay really thank you ~~~
