Announcements
Exporting Multiple Selected Object Groups
john.baumchen
john.baumchen
Hello all,
I've got a Max file with many object groups with textures.  I'd like to select some or all and export them to .obj with their textures with a scale of 1.0, and maintain them as individual groups with their individual group names.  I'm not very profeicient at Max scripting and was wondering if anyone else has addressed this and would be willing to share the script for it.  I've located something that will do it from frames, but am unable to decipher the code.  I'm working in 3dsMax 2019.
Thanks and cheers.
denisT.MaxDoctor
do you want to export each group to a separate file?
john.baumchen
Yes
denisT.MaxDoctor
/*********** SAMPLE SCENE **********/
delete objects
gc()
with redraw on
	t0 = for k=0 to 8 collect
		t = teapot name:(uniquename #red_teapot_) radius:19 pos:[4,0,0] rotation:(eulerangles 0 0 (k*40)) wirecolor:red
	gr0 = group t0 name:#red_group
	move gr0 [-50,0,0]
	t1 = for k=0 to 9 collect
		t = teapot name:(uniquename #green_teapot_) radius:15 pos:[10,0,0] rotation:(eulerangles 0 0 (k*36)) wirecolor:green
	gr1 = group t1 name:#green_group
	move gr1 [50,0,0]
	t2 = for k=0 to 8 collect
		t = teapot name:(uniquename #orange_teapot_) radius:20 pos:[-6,0,0] rotation:(eulerangles 0 0 (k*40)) wirecolor:orange
	gr2 = group t2 name:#orange_group
	move gr2 [0,50,0]
	t3 = for k=0 to 9 collect
		t = teapot name:(uniquename #blue_teapot_) radius:13 pos:[-16,0,0] rotation:(eulerangles 0 0 (k*36)) wirecolor:blue
	gr3 = group t3 name:#blue_group
	move gr3 [0,-50,0]
/*********************** METHODS **********************/
fn collectGroupHeads =
	for obj in objects where isGroupHead obj collect obj
fn collectHeadGroup head = if isGroupHead head do
	join #() head
fn exportSetup =
	file = objExp.getIniName()
	if doesFileExist file then
		setINISetting file #Material #UseMaterial "1"
		setINISetting file #Geometry #ObjScale "1.000"
		true
	else false
fn exportHeadGroup head dir: = if isGroupHead head do
	if dir == unsupplied do dir = getdir #temp
	makeDir dir all:on -- just in case the path doesn't exist
	cursel = selection as array
	nodes = collectHeadGroup head
	select nodes
	filename = pathConfig.appendPath dir (head.name + ".OBJ")
	res = exportFile filename #noPrompt selectedOnly:on using:ObjExp
	if cursel.count == 0 then clearselection() else select cursel
	if res do filename
fn exportHeadGroups dir: setup:on =
	if dir == unsupplied do dir = getSavePath()
	if dir != undefined do
		heads = collectGroupHeads()
		exported = #()
		if heads.count > 0 do with redraw off, undo off
			if setup do exportSetup()
			exported = for head in heads collect
				expfile = exportHeadGroup head dir:dir
				if expfile != undefined then #(head, expfile) else dontcollect
		exported
/************ RUN BELOW TO DO THE EXPORT ****************
res = exportHeadGroups()
feel free to ask questions if you encounter a problem or want more details...
john.baumchen
denisT,
Thank you for taking the time to help me with this, I'd have spent weeks first learing another language, then trying and most probably failing to accomplish the task. Just want you to know how much I appreciate your help.
Cheers.
