ExecuteMAXScriptScript issue.
klvnk
Message 1 of 8
klvnk
when the a script is run that returns a Color with an alpha the  return FPValue of
Color 255 255 255 254
is of  TYPE_FRGBA_BV,  all well and good.  the resultant aclr of the FPValue is 1.0,1.0,1.0 0.99607849.
though if it returns something like
Color 255 255 255 255
the resultant aclr is 1.0,1.0,1.0,0.0
any alpha value of 255 results in zero being returned
Replies (7)
Message 2 of 8
klvnk
though
c = Color 123 111 96 255
c as Point4
and
b = Color 4 56 192 255
#(c,b)
both work as expected :?
Message 3 of 8
denisT.MaxDoctor
I can't reproduce the issue. I try to execute the string in different ways and try to compile the string, and each time I get the expected result where the alpha is 255.0 as was passed.
Message 4 of 8
klvnk
should be 1.0 as it's passed as the AColor* FPValue::aclr;
Message 5 of 8
klvnk
this should reproduce it
def_visible_primitive(runscript, "runscript");
Value* runscript_cf(Value** arg_list, int count)
	enum args { kscript, kquiet, knum_args };
	check_arg_count(runscript, knum_args, count);
	FPValue  result;
	ExecuteMAXScriptScript(arg_list[kscript]->to_string(), arg_list[kquiet]->to_int(), &result);
	return new Point4Value(result.aclr->r, result.aclr->g, result.aclr->b, result.aclr->a);
then try....
runscript "c = color 128 128 128 255;\nc;" true
in the listener, followed by...
runscript "c = color 128 128 128 254;\nc;" true
Message 6 of 8
klvnk
I think i know what's happening now when it sees the 255 as the alpha it changes it from a "AColor" to a "Color" so therefore passed in the  FPValue::clr. I wasn't paying enough attention to the FPValue::type field and the crazy nature of c/cpp unions 🙂
Message 7 of 8
denisT.MaxDoctor
check InterfaceFunction::FPValue_to_val
Message 8 of 8
klvnk
I already use  it for the mxs function, this issue came up in a com server implementation which returns variants and or safearrays...
the fix was one line...
case TYPE_FRGBA_BV:
case TYPE_COLOR_BV:
        if (ret.type == TYPE_COLOR_BV) ret.aclr->a = 1.0f;
	var_safearray_from_val<float>(4, (float *)ret.aclr, result);
	break;
