Error while trying to package project for Android
Hello everyone,
I'm writing here because I need your help with Autodesk 3ds Max Interactive.
Indeed, when I try to use the deployer to package my project for Android, I get this error :
Editor / General: Android Packager: Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.AndrolibException: brut.common.BrutException: could not exec: [aapt, p, --forced-package-id, 127, --min-sdk-version, 21, --target-sdk-version, 25, --version-code, 1, --version-name, 1.0, -F, C:\Users\Audrey\AppData\Local\Temp\APKTOOL6937764462712938532.tmp, -0, arsc, -0, arsc, -I, C:\Users\Audrey\AppData\Local\apktool\framework\1.apk, -S, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\res, -M, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\AndroidManifest.xml]
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:478)
at brut.androlib.Androlib.buildResources(Androlib.java:412)
at brut.androlib.Androlib.build(Androlib.java:311)
at brut.androlib.Androlib.build(Androlib.java:264)
at brut.apktool.Main.cmdBuild(Main.java:227)
at brut.apktool.Main.main(Main.java:84)
Caused by: brut.androlib.AndrolibException: brut.common.BrutException: could not exec: [aapt, p, --forced-package-id, 127, --min-sdk-version, 21, --target-sdk-version, 25, --version-code, 1, --version-name, 1.0, -F, C:\Users\Audrey\AppData\Local\Temp\APKTOOL6937764462712938532.tmp, -0, arsc, -0, arsc, -I, C:\Users\Audrey\AppData\Local\apktool\framework\1.apk, -S, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\res, -M, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\AndroidManifest.xml]
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:439)
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:464)
... 5 more
Caused by: brut.common.BrutException: could not exec: [aapt, p, --forced-package-id, 127, --min-sdk-version, 21, --target-sdk-version, 25, --version-code, 1, --version-name, 1.0, -F, C:\Users\Audrey\AppData\Local\Temp\APKTOOL6937764462712938532.tmp, -0, arsc, -0, arsc, -I, C:\Users\Audrey\AppData\Local\apktool\framework\1.apk, -S, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\res, -M, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\AndroidManifest.xml]
at brut.util.OS.exec(OS.java:97)
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:433)
... 6 more
Caused by: java.io.IOException: Cannot run program "aapt": CreateProcess error=2, Le fichier spÚcifiÚ est introuvable
at java.base\java.lang.ProcessBuilder.start(ProcessBuilder.java:1128)
at java.base\java.lang.ProcessBuilder.start(ProcessBuilder.java:1071)
at brut.util.OS.exec(OS.java:90)
... 7 more
Caused by: java.io.IOException: CreateProcess error=2, Le fichier spÚcifiÚ est introuvable
at java.base\java.lang.ProcessImpl.create(Native Method)
at java.base\java.lang.ProcessImpl.(ProcessImpl.java:420)
at java.base\java.lang.ProcessImpl.start(ProcessImpl.java:151)
at java.base\java.lang.ProcessBuilder.start(ProcessBuilder.java:1107)
... 9 more
Do you know how I could fix this? I followed all those steps :
help.autodesk.com/view/Stingray/ENU/?guid=__stingray_help_getting_started_get_started_android_html
But I still get this error.
Also it's the first time I'm using 3DS Max Interactive, I work on Revit usually but I'm trying to export my construction in Revit to 3DS Max Interactive to see it in VR.
Thank you for your help!
