error msg: attempt to access deleted nodes
02:37 AM
This block of codes intents to create a object which describes the geometry informations of traffice symbol lines, including the width ,the length, the spacing between to short lines, make polygon copys of the lines,and keep the polygon copys(as an array) as a attribute so that I can access the type conveniently.
My first language is not English, apologize for my poor expression.
Anyway , codes talk:
then I run these codes:
then when I run this line: select a.polys
It says "attempt to access deleted nodes".
I prefer that when I change a's property and run a.makePolys() again ,it will CHANGE the Polys into a new version but not CREATE a new version of polys. But however, the "deleted Nodes" thing now is getting in my way.
Any help?
struct trafficLine
name,
width = 0.15,
length,
spacing,
guideLines = #(),
Polys = #(),
fn makePolys =
if polys.count != 0 then for i in polys do delete i
polys = #()
tempPart = plane width:length length:width name:(uniqueName name) lengthsegs:1 widthSegs:1 mapcoords:on
for i in guideLines do
currentPoly = MakeStripPoly i tempPart spacing 0.5 off
--function "MakeStripPoly" will return a polygon object made by given parameters.
append polys currentPoly
fn resetGuidelines =
guideLines = #()
fn resetPolys =
polys = #()
fn nameGuideLines =
for i in guideLines do i.name = uniqueName (name + "_GuideLine")
a = trafficLine name:"haha" guideLines:(for i in selection where canConvertTo i splineshape collect i) width:0.15 length:2 spacing:4
a.width = 3
a.length = 5
a.spacing = 4
--a.setGuidelinesBySelection()
a.makePolys()
Any help?
