Announcements
Enviroment variables for specific version of 3dsmax
Richard_Commin
Message 1 of 1
Richard_Commin
Hi There,
Not sure if I'm going about this in the right way. So any help is much appreciated!
I'm looking to setup two 3dsmax 2025 installs for two different users, but using the same plugins and scripts etc.
What is the easiest way of doing this?
I would like to have as much as possible outside of the AppData\Local\Autodesk\3dsMax\2025 - 64bit\ENU folder
I've tried setting up custom paths and using Environment Variables that point to a user folder. I've run into some issues with the Env variables affecting older installations of 3dsmax.Is there a way of defining a ENV variable that only affects 3dsmax 2025? I've read the documentation about minor and major versions, which is not quite what I'm looking for here. Maybe something I'm not understanding?
Also having some issues with creating call back scripts to deal with scripts that are buttons finding a user-scripts folder in a different location as expected.
Thanks in Advance!
Replies (0)
