Embed external application
tagopinath
tagopinath
Hello everyone,
I am trying to embed as external application inside 3ds Max through Qt dialog in our plugin.
This is working fine, but issue is, i am not able to see the Title and Menu bar of that external application.
Here is the code what i am trying.
            QWindow* window = QWindow::fromWinId(hWnd);
            QWidget* container = QWidget::createWindowContainer(window);// , centralWidget);
            QMdiSubWindow* subWindow = new QMdiSubWindow(this);
            subWindow->setWidget(container);
            subWindow->setAttribute(Qt::WA_DeleteOnClose);
            subWindow->setWindowTitle("Program 1");
            subWindow->setWindowState(Qt::WindowMaximized);
            Qt::WindowFlags flags = subWindow->windowFlags();
            flags |= Qt::FramelessWindowHint;
            flags |= Qt::WindowSystemMenuHint;
            subWindow->setWindowFlags(flags);
            container->show();
            QHBoxLayout* buttonLayout = new QHBoxLayout(this);
            buttonLayout->addWidget(container);
            QVBoxLayout* mainLayout = new QVBoxLayout(this);
            //// ... add other widgets ...
            mainLayout->addLayout(buttonLayout);
            mainLayout->addStretch();
            setLayout(mainLayout);
in Qt, they are saying no option to show the menu.
i tried the other way without using Qt (using SetParent), in that method, its showing menu and title bar.  But issue is, whenever a dialog is opened in the external application, then this embedded dialog is getting hidden. and click on viewport again, its showing again.
Is there any other way to implement this ? Please suggest.
Gopinath.
denisT.MaxDoctor
What kind of external application?
istan
@tagopinath wrote:
I am trying to embed..
What do you mean with "embed"? How you did that in Max?
denisT.MaxDoctor
Let's make our list of questions complete...
Why do you need to embed? 😁
tagopinath
Hi Denis and istan,
Thanks for your questions.
I just wanted to bring one other application inside 3ds max.
I found a simple way to do that by making max window as parent and external application hwnd as child, which is working fine.
Thanks again for your time.
Gopi.
