Edit macro button appearance
denisT.MaxDoctor
Advisor Advisor
denisT.MaxDoctor
Does anyone know for sure what the system does when you try to change the appearance of a macro button using the RightClick menu?
I don't see any SKD methods for this, so I assume it's just some data stored in some "INI" file.
Ideally, I want to catch this moment.
(monitoring some file or directory is not a problem for me... I just need to know where the changes are)
Serejah
Appearance of all these buttons is saved on max session end (don't know if you can force it using maxscript) in .cuix file that you can find using workspace methods
WorkspaceManager.GetCurrentWorkspaceIdentifier()
WorkspaceManager.GetWriteDirectory()
upd
local g = (dotNetClass "Autodesk.Max.GlobalInterface").Instance
g.CUIFrameMgr.WriteConfig -- accessing this property forces max to save .cuix file
g.coreinterface7.loadcuiconfig g.CUIFrameMgr.ConfigFile -- force reload workspace
if it is the only button you need to track then perhaps you could subclass it and wait for a WM_COMMAND with lparam equal to 47816 which is sent when Edit Button Appearance... menu item is clicked. And then subclass this modal window and wait for WM_COMMAND with lparam equal to IDOK. Way too hacky to call it safe to use, imo
denisT.MaxDoctor
yeah... thanks for the confirmation. Finally, everything is stored in the specified .cuix. During the MAX session they are probably modifying the Action Table which I have access to through the SDK. So I'm almost "happy" with what I have.
