Dynamic slider range
I want to by able to alter the range values of a slider dynamically. In this example the button is meant to cap the slider's range from 100 to 50, but it doesn't seem to work. Can someone tell me what I am doing wrong? Do I need to update the slider with the new range? Thank you.
rollout dynamicSlider "Dynamic Slider Test" width:150 height:150
local sldRange =
slider maxSlider "Slider" pos: width:120 height:44
label maxSliderLBL "" pos: width:120 height:22 range:sldRange
button btn1 "Button" pos: width:80 height:25
on maxSlider changed val do
maxSliderLBL.text = maxSlider.value as string
on btn1 pressed do
sldRange=
print sldRange
if maxSlider.value > 50 then maxSlider.value = 50
createDialog dynamicSlider
miauuuu
on btn1 pressed do
sldRange =
if maxSlider.value > 50 do
maxSlider.range = sldRange
https://miauu-maxscript.com/
Thank you for the extremely quick reply! Whilst on the subject of sliders; is it possible to make a vertical slider with a height of more than 100?
barigazy
Just use orient property for the slider. See this page
miauuuu
The slider control do not have length and width property, so you can't create a slider with length = 50. The orientation can be changed - follow the link from the Branko.
But, actually, you can create sliders with custom length. Just follow this link and don't forget to give credit to Denis Trofimov
