Announcements
Drag and Drop with PySide into Main Max Window
mitchell.lotierzoJ5X6W
If I get the instance of the main 3ds Max window with `QWidget.find(rt.windows.getMAXHWND())`, is it possible to somehow override the `dropEvent` of that window to accept drops from a QDialog created with PySide?
Is it even possible to do drag and drop from PySide into the main 3ds Max application?
Swordslayer
from qtmax import GetQMaxMainWindow
from PySide2 import QtCore, QtGui, QtWidgets
from PySide2.QtWidgets import QDialog, QHBoxLayout
class DragButton(QPushButton):
    def mouseMoveEvent(self, e):
        if e.buttons() == QtCore.Qt.RightButton:
            return
        mimeData = QtCore.QMimeData()
        mimeData.setUrls([QtCore.QUrl.fromLocalFile("C:\\path\\file.max")]) # or file.jpg etc.
        drag = QtGui.QDrag(self)
        drag.setMimeData(mimeData)
        drag.start(QtCore.Qt.MoveAction)
class Window(QDialog):
    def __init__(self, parent=None):
        super(Window, self).__init__(parent)
        self.setWindowTitle('Drag & Drop')
        self.setLayout(QHBoxLayout())
        self.layout().addWidget(DragButton("Drag Me"))
dialog = Window(GetQMaxMainWindow())
dialog.show()
Swordslayer
Or if you want to do something more custom, like dropping some objects on construction plane, you can do it this way:
from pymxs import undo as max_undo, runtime as rt
class MaxEvents(QtCore.QObject):
    def eventFilter(self, object, event):
        if (event.type() == QtCore.QEvent.DragEnter):
            print("Drag enter")
        elif (event.type() == QtCore.QEvent.DragMove):
            print("Drag move")
        elif (event.type() == QtCore.QEvent.Drop):
            self.parent().dropped.emit()
        return False
class DragButton(QtWidgets.QPushButton):
    dropped = QtCore.Signal()
    mainWin = GetQMaxMainWindow()
            return
        filter = MaxEvents(parent = self)
        self.mainWin.installEventFilter(filter)
        mimeData.setUrls([])
        try:
        finally:
            self.mainWin.removeEventFilter(filter)
            self.setDown(False)
class Window(QtWidgets.QDialog):
        self.setLayout(QtWidgets.QHBoxLayout())
        btn = DragButton("Drop Box")
        btn.dropped.connect(self.spawnBox)
        self.layout().addWidget(btn)
    def spawnBox(self):
        if (rt.mouse.pos.x > 0 and rt.mouse.pos.y > 0 and rt.mouse.pos.x <= rt.gw.getWinSizeX() and rt.mouse.pos.y <= rt.gw.getWinSizeY()):
            with max_undo(True):
                rt.Box(length = 5, width = 5, height = 5, pos = rt.mapScreenToCP(rt.mouse.pos))
            rt.redrawViews()
        else:
            print("Dropped outside of active viewport")
w = Window(GetQMaxMainWindow())
w.show()
@Swordslayer I appreciate the detailed response and the two options you provided. I meant to actually post an update back on Friday, but work got the best of me. I stumbled upon the whole concept of using the `eventFilter` on Friday and do like that approach better. Interestingly, I tried an approach similar to your first example, but couldn't get the Max main window to accept the drag, but I wasn't using `qtmax`, I was just getting the window via the runtime, so maybe that was the issue. I need to look more into the `qtmax` module.
Thanks again! Cheers!
Swordslayer
The qtmax method (or MaxPlus one in older max versions) is basically the same thing as QtWidgets.QWidget.find(rt.windows.getMaxHWnd()), the important thing to make max accept the drop is to have an array of urls set in the mimeData (it can be empty if you don't want max to use what's in it, mimeData.setUrls([]) should still work).
