Dotnet system.guid - inaccessible in maxscript.
jonahhawk2
jonahhawk2
I am having trouble getting at “System.Guid” as a dotNetObject. Loading the assembly does not work either.
Has anyone else had issues with this or is it just me?
I have written a substitute for it which generates hex values in the same format, but somehow I feel better about using the dotnet version.
thanks in advance
denisT.MaxDoctor
guid = (dotnetclass "System.Guid").NewGuid()
guid.ToString()
where is the problem?
jonahhawk2
Thank you, Dennis. I am the problem.
Why is loading Guid different than loading System.xml or System.regEx (forgive my capitalization, I don't know the case by heart)
denisT.MaxDoctor
System.Guid is an Object, and it has its own constructors. Usually you should read documentation 😉 but if you are lazy like me you can check a .NET object constructor by calling for example for this case:
dotnet.showconstructors (dotnetclass "System.Guid")
and you will see that there is no simple constructor as (dotneobject "System.Guid")
so you need a special way... and you can check class methods:
showmethods (dotnetclass "System.Guid")
where ".NewGuid()" looks like yours
