Announcements
delete polygon using maxsccript
i create a polygon in max scrip by this way
vertices = #([0,0,0], [100,0,0], [100,100,0], [0,100,0])
obj = convertToPoly (mesh vertices:vertices faces:#())
polyOp.createPolygon obj #(4,3,2,1)
and need to delete it again as i draw it only  to get normal
Swordslayer
It would be better and faster to calculate the normal yourself, i.e. from your set of points:
p3 = [100,0,0]
p2 = [100,100,0]
p1 = [0,100,0]
faceNormal = normalize (cross (p3 - p2) (p1 - p2))
Cross product will give you a vector perpendicular to the vectors (from p3 to p2 and from p1 to p2 here) - this is the way normals are computed for meshes.
