DDS Unsupported DDS Image File in English
Message 1 of 30
----------Well, I had to make this post again because It seems like nobody speaks spanish around here and I need to find a solution to my problem.------------
I started working with a new model a few days ago on which I rigged and now works perfectly and which I hoped to make a very good render.
At the beginning I could open the textures that this model has and they worked fine, but for some reason this message started to show everytime I wanted to use a DDS texture:
Honestly, I don't know what could have happened. The only thing I did was to open one of these textures with Photoshop CS4 to create a bump and a specular map with the same format.
I hope you can help me with this!
Replies (29)
Message 21 of 30
Tried to merge it but I got this error
Message 22 of 30
Alfred.DeFlaminis
Hello @Anonymous,
I've been reading over the thread and double checking everything when I noticed you are on 3ds Max 9.  That is the problem here, the .png format has advanced a lot since then and I'd bet it cannot read those files properly because of that.  Unfortunately I don't have Max 9 to test on and officially I am only supposed to support 2014-2017 or current version minus three, so I think we're at an impasse here.
I will reiterate my suggestion that you use a different texture format.  Max 9 is very old and likely not going to work properly on any operating system that it wasn't built for without using compatibility layers in Windows.  I should have asked which version it was for earlier so that's on me.  I think Max 9 was Windows XP and Windows 2000 if you want to try those modes for compatibility.
Best Regards,
Message 23 of 30
Hi @Alfred.DeFlaminis , is it possible if you merge my scene into a new one? I can't do it, I've tried. That's last think I can think of.
Message 24 of 30
Alfred.DeFlaminis
I will do anything in my power to help you, always.  The problem though @Anonymous is that I only have Max 2017 - 2014 installed, so the best I can do is save it back to Max 2014.  If you are on Max 9 though, the file will not open in it.  Do you have access to any more recent versions of 3ds Max?
Best Regards,
Message 25 of 30
Alfred.DeFlaminis
Hello @Anonymous,
Just wanted to check in and see if you had any thoughts about my previous post.  Thanks!
Best Regards,
Message 26 of 30
Hi @Alfred.DeFlaminis ,how are you doing? Sorry I had troubles with my network but it's fine now. I use 3ds Max 09 because my pc is not as great as I wish it was. I could try downloading the 2014 version though. If that doesn't work, I don't know what else to do. Maybe you can convert my DDS textures to PNG/JPG ?
Thank you!!
Message 27 of 30
Alfred.DeFlaminis
Hello @Anonymous,
No problem at all, I wasn't trying to be pushy.  I just wanted to make sure you were all set.  I'd be happy to convert your images, but I need to do it at home because my work laptop doesn't have Photoshop on it currently.  Did you need them all converted?  (No problem.)  I can't see a way out of this issue for you if these aren't converted, so I think it's ok and I am happy to do it.  I'll have them uploaded for you by tomorrow night at the latest, will try to do it tonight.
Best Regards,
Message 28 of 30
Thank you very much Alfred!
Message 29 of 30
Alfred.DeFlaminis
Not a problem at all @Anonymous.  I feel guilty that I didn't notice the Max 9 thing sooner, so I am doubly happy to help.
Best Regards,
Message 30 of 30
kking8
Community Visitor
Community Visitor
I don't know if this will help you or what version you are using. but the modding community might be able to come to your aid
https://www.nexusmods.com/fallout4/mods/20540
DX11 dds read in compiled for 2013 don't know if this helps you. I hope it does. If not ignore me. sorry 🙂
