Creating and using a rollup window
Hi all!
I was wondering if anyone know of any example code of creating and using rollup windows and panels?? Outside of the command panel?!
Cheers
Shane
Would it depend on the type of plugin? If its a utility or modifier plugin, then you are stuck in the command panel. Or are you thinking of creating a modal dialog that gets called from your plugin and it has the rollup panels?
Mike
It would depend - I intend on creating my own custom windows and applying the rollup's to that dynamically.
